hellbent1
May 20, 2010Aspirant
Automatic 0.6.2 on Duo Issues
I've been trying to get automatic running on my Duo for the last few days with little to no success. I'm not much for unix so that doesn't help matters but i'll walk you thru where i've gotten to. ...
emc
Aug 25, 2011Aspirant
Can you post conf which really works!
My:
produce:
My:
transmission-version = "1.3"
rpc-host = "localhost"
rpc-port = 9091
rpc-auth = "admin:password1"
feed = {url => "http://ezrss.it/feed"
url => "http://thepiratebay.org/rss"}
interval = 30
use-transmission = no
start-torrents = no
torrent-folder = "/tmp"
statefile = "~/.config/automatic.state"
filter = { pattern => "Star.Wars.The.Clone.Wars.S03E*HDTV.XviD-FQM" }
produce:
flap:/etc/frontview/addons/bin/AUTOMATIC# automatic -f -v 3
automatic: /usr/lib/libcurl.so.3: no version information available (required by automatic)
../src/config_parser.c, 431: Configuration file size: 362
../src/config_parser.c, 601: [parse_config_file] option: transmission-version
../src/config_parser.c, 602: [parse_config_file] param: 1.3 (3 byte)
../src/config_parser.c, 603: [parse_config_file] -----------------
../src/config_parser.c, 320: transmission-version=1.3 (type: 0)
../src/config_parser.c, 601: [parse_config_file] option: rpc-host
../src/config_parser.c, 602: [parse_config_file] param: localhost (9 byte)
../src/config_parser.c, 320: rpc-host=localhost (type: 0)
../src/config_parser.c, 601: [parse_config_file] option: rpc-port
../src/config_parser.c, 602: [parse_config_file] param: 9091 (4 byte)
../src/config_parser.c, 320: rpc-port=9091 (type: 1)
../src/config_parser.c, 601: [parse_config_file] option: rpc-auth
../src/config_parser.c, 602: [parse_config_file] param: admin:password1 (15 byte)
../src/config_parser.c, 320: rpc-auth=admin:password1 (type: 0)
../src/config_parser.c, 561: reading multiline param
../src/config_parser.c, 575: multiline param: param_good=0
../src/config_parser.c, 601: [parse_config_file] option: feed
../src/config_parser.c, 602: [parse_config_file] param: url => "http://ezrss.it/feed"
url => "http://thepiratebay.org/rss" (66 byte)
../src/config_parser.c, 320: feed=url => "http://ezrss.it/feed"
url => "http://thepiratebay.org/rss" (type: 2)
../src/regex.c, 95: [getRegExMatch] Text to match against: http://thepiratebay.org/rss (27 byte)
../src/config_parser.c, 601: [parse_config_file] option: interval
../src/config_parser.c, 602: [parse_config_file] param: 30 (2 byte)
../src/config_parser.c, 320: interval=30 (type: 1)
../src/config_parser.c, 601: [parse_config_file] option: use-transmission
../src/config_parser.c, 602: [parse_config_file] param: no (2 byte)
../src/config_parser.c, 320: use-transmission=no (type: 1)
../src/config_parser.c, 601: [parse_config_file] option: start-torrents
../src/config_parser.c, 320: start-torrents=no (type: 1)
../src/config_parser.c, 601: [parse_config_file] option: torrent-folder
../src/config_parser.c, 602: [parse_config_file] param: /tmp (4 byte)
../src/config_parser.c, 320: torrent-folder=/tmp (type: 0)
../src/config_parser.c, 601: [parse_config_file] option: statefile
../src/config_parser.c, 602: [parse_config_file] param: ~/.config/automatic.state (25 byte)
../src/config_parser.c, 320: statefile=~/.config/automatic.state (type: 0)
../src/config_parser.c, 601: [parse_config_file] option: filter
../src/config_parser.c, 602: [parse_config_file] param: pattern => "Star.Wars.The.Clone.Wars.S03E*HDTV.XviD-FQM" (58 byte)
../src/config_parser.c, 320: filter= pattern => "Star.Wars.The.Clone.Wars.S03E*HDTV.XviD-FQM" (type: 2)
../src/automatic.c, 519: verbose level: 3
../src/automatic.c, 520: Transmission version: 1.3
../src/automatic.c, 521: RPC host: localhost
../src/automatic.c, 522: RPC port: 9091
../src/automatic.c, 523: RPC auth: admin:password1
../src/automatic.c, 524: foreground mode: yes
../src/automatic.c, 525: config file: /etc/automatic.conf
../src/automatic.c, 526: Transmission home: /root/.config/transmission
../src/automatic.c, 527: check interval: 30 min
../src/automatic.c, 528: Upload limit: -1 KB/s
../src/automatic.c, 529: torrent folder: /tmp
../src/automatic.c, 530: start torrents: no
../src/automatic.c, 531: state file: /root/.config/automatic.state
../src/automatic.c, 535: 1 feed URLs
../src/automatic.c, 536: Read 1 filters from config file
../src/state.c, 100: [load_state] Error: Unable to open statefile '/root/.config/automatic.state' for reading: No such file or directory
[11/08/25 21:27:25] ../src/automatic.c, 565: ------ Checking for new episodes ------
../src/automatic.c, 578: Checking feed 1 ...
../src/web.c, 401: [getHTTPData] url=http://thepiratebay.org/rss, curl_session=(nil)
../src/web.c, 366: [am_curl_init] Created new curl session 0x39d70
../src/web.c, 188: [write_data_callback] allocated 102400 bytes for mem->response->data
../src/web.c, 438: [getHTTPData] response code: 0
../src/automatic.c, 432: [processFeed] curl_session=0x39d70
Entity: line 59: parser error : Entity 'nbsp' not defined
<b><a href="/" title="Search Torrents">Search Torrents</a></b> |&n
Entity: line 60: parser error : Entity 'nbsp' not defined
<a href="/browse" title="Browse Torrents">Browse Torrents</a> |&nb
Entity: line 61: parser error : Entity 'nbsp' not defined
<a href="/recent" title="Recent Torrent">Recent Torrents</a> |&nbs
Entity: line 62: parser error : Entity 'nbsp' not defined
<a href="/tv" title="TV shows">TV shows</a> |
Entity: line 63: parser error : Entity 'nbsp' not defined
<a href="/music" title="Music">Music</a> |
Entity: line 134: parser error : Entity 'nbsp' not defined
<h2><span>Subscribe</span> </h2>
Entity: line 185: parser error : Opening and ending tag mismatch: body line 50 and div
</div><!-- //div:content -->
Entity: line 227: parser error : Opening and ending tag mismatch: html line 2 and body
</body>
Entity: line 228: parser error : Extra content at the end of the document
</html>
../src/xml_parser.c, 170: Error: Unable to parse input data!
../src/automatic.c, 444: History bucket size changed: 30
../src/list.c, 228: [cleanupList] size before: 0
../src/list.c, 239: [cleanupList] size after: 0
../src/web.c, 570: [closeCURLSession] Closing curl session 0x39d70
../src/automatic.c, 583: New bucket size: 30
hellbent wrote: wait, i got it. the parser is VERY particular about having the curly braces on the following line and no extra whitespace or tabs. seems to be working with multiple filters now.
many thanks Stefan!
