irv1
Jan 22, 2012Aspirant
Bitcasa on Readynas?
Does anyone know if its likely that Bitcasa will ever be available as an addon for readynas? info http://www.bitcasa.com/about, they are planning a linux release. invites https://portal.bitcasa....
JMehring
Nov 22, 2013Apprentice
BTW, To reliability upload initial mass data to Bitcasa use the ReadyNAS Backup system using rsync. It works really well!!!
Just a note though that the ReadyNAS will create a snaphot when backing up, so if you delete files or cancel the download before it is finished the snapshot will still be present and you will not be able to free up space on the shares.
I can also provide info on how to remove the temporary snapshots the backup program creates if needed since i noticed the backup program does not remove them for me if I cancel the backup before its completed.
