Gelangweilt
Jul 10, 2009Aspirant
bittorrent not working
Hello! my bittorrent downloads wont work. when i add a torrent via file or link the download wont start. actually nothing happens. can someone share some ideas where i should start looking for...
Fayez
Jul 12, 2009Aspirant
Very strange.
Here's two more things you can try, after which it may be time to call Netgear support:
1. Try connecting your ReadyNAS to a different port on your router (and maybe with a different cable too)... Hey, might as well rule out everything that you can...
2. Log into Frontview (https://<yournasnameoripaddress>/admin), and check your settings under Network > Interfaces > Standard, and make sure "IP assignment" is set to "Use values from a DHCP server".
