Barney_Gumble
Dec 29, 2011Aspirant
Calibre - E-Book Management Add-On
Hi, not sure if this is the correct place for this question, but it's my best guess!
I was wondering if there was an Add-On for the Calibre E-Book Management doohickey?
For those who don't know, Calibre provides the ability to download newspapers and websites, converts them into e-book format, and emails them direct to your kindle (Or other device) each day, at a set time. Given that Calibre needs to be running in order to perform this conversion, it would seem to be an ideal candidate for an add-on for a ReadyNas...
Any help/advice much appreciated.
Ta,
Barney
Ta,
Barney
- sphardy1ApprenticeNot sure that is possible/practical - Calibre has a full graphical interface that would not be accessible running headless on the NAS and the web interface does not provide the same level of control (none actually)
Unless there is some other control option - Barney_GumbleAspirantAye - good point well made. Oh well, ta for the quick response though!
- Retired_Member
sphardy wrote: Not sure that is possible/practical - Calibre has a full graphical interface that would not be accessible running headless on the NAS and the web interface does not provide the same level of control (none actually)
I could live with using the desktop version to set up & manage the library on the NAS, as long as the NAS could then serve up the books to remote clients - i.e. Android devices in my case. There are plenty of apps that can browse the calibre catalog (Aldiko, click My Catalogs, CalibreLibrary, Leger Calibre, etc.). - banjopickerAspirantCalibre has a command line interface as well that would be useful to use on the ReadyNAS via ssh. This way you could setup cron jobs so that it could automatically create e-book versions of the magazines and newspapers that it supports.
Unfortunately, I cannot get the linux version of Calibre to install because it doesn't have a working version of bzip2, and when I try to install it I get the following:BigBertha:/usr/bin/calibre# sudo python -c "import sys; py3 = sys.version_info[0] > 2; u = __import__('urllib.request' if py3 else 'urllib', fromlist=1); exec(u.urlopen('http://status.calibre-ebook.com/linux_installer').read()); main()"
Enter the installation directory for calibre [/opt]:
Will download and install calibre-0.8.34-i686.tar.bz2
Downloading calibre-0.8.34-i686.tar.bz2
100% [=========================================================================================================]
Downloaded 49198179 bytes
Checking downloaded file integrity...
tar (child): bzip2: Cannot exec: No such file or directory
tar (child): Error is not recoverable: exiting now
tar: Child returned status 2
tar: Error is not recoverable: exiting now
Traceback (most recent call last):
File "<string>", line 1, in <module>
File "<string>", line 285, in main
File "<string>", line 243, in download_and_extract
File "<string>", line 228, in download_tarball
File "/usr/lib/python2.6/subprocess.py", line 488, in check_call
raise CalledProcessError(retcode, cmd)
subprocess.CalledProcessError: Command '[u'tar', u'tjf', '/tmp/tmpm5r1AL']' returned non-zero exit status 2
And then when I try to install bzip2:BigBertha:/usr/bin/calibre# apt-get install bzip2
Reading package lists... Done
Building dependency tree... Done
Some packages could not be installed. This may mean that you have
requested an impossible situation or if you are using the unstable
distribution that some required packages have not yet been created
or been moved out of Incoming.
Since you only requested a single operation it is extremely likely that
the package is simply not installable and a bug report against
that package should be filed.
The following information may help to resolve the situation:
The following packages have unmet dependencies:
bzip2: Depends: libbz2-1.0 (= 1.0.3-6) but 1.0.5-6 is to be installed
E: Broken packages
Can anyone help? Thanks. - WhoCares_Mentor
- banjopickerAspirantThanks for the quick response. I'm afraid though that my powers don't extend much beyond apt-get, so I'd need a little more hand-holding to install the deb file. I will google it--thanks.
- WhoCares_Mentordpkg -i <name of .deb file> ;)
Btw: you are aware that the version of Python on the ReadyNAS most likely is too old for Calibre?
-Stefan - banjopickerAspirantYeah, I realize that might be a problem. The version I have installed is 2.6.6, Calibre's page says 2.7.1, but it looks like it only checks for >2, so I am wondering if it will install with 2.6.x anyway.
- WhoCares_MentorFrom my experience it won't but I wish you luck with the endeavor ;)
-Stefan
