b1jzcbx
Jul 10, 2023Tutor
can i restore a deleted volume? - PLEASE HELP!!
I'M IN A massive amount of trouble with this... i was adding drives and formatting them, and somehow all drives were selected, and it deleted the main volume.
i have an rndp6000-200 updated to 6.10.8.
i'm sure i'm completely screwed.. i tried looking for a metadata folder in etc but there's nothing..
i have no backups of this.. i know the answer but i'm hopeful someone knows something that i definitely don't
- eden60Aspirant
Stop using the drives: Don't do anything else with the drives to avoid making things worse.
Contact a data recovery specialist: Seek help from professionals who can recover your data.
Check for volume recovery options: Look for any instructions or guidance specific to your device model on how to recover the deleted volume.
Look for backups or snapshots: Check if you have any previous backups or snapshots of your data stored elsewhere.
Contact the manufacturer: Get in touch with the manufacturer of your device for assistance and advice.
Remember, it's important to act quickly and consult experts to increase the chances of recovering your lost data. - MikeD1234NETGEAR Expert
Hi b1jzcbx,
eden60 is correct, don't have the device powered on anymore, the more it's on, the more it'll overwrite data on the disk, where previous data was stored.
When you do a Factory Default, or, reset of the disks, it's clearing the metadata on the disk, but, doesn't fully zero-out the disks, this only happens on a full reset.
I would advise to contact a DR company, as they are maybe able to retrieve what was on the disk, with their hardware/software, as long as you didn't do a full wipe, but instead a quick factory default...
Hope this helps.
It might already be too late.
There are some companies out there that specialize in data recovery. Seagate has a data recovery service.
If you want to try doing this yourself, you can try connecting all the disks to a PC (probably needing a multi-bay enclosure), and then use ReclaiMe Ultimate (which supports BTRFS and software RAID). You'd also need to have enough storage to offload the data.
Could easily run about $800 to get the enclosure, software, and storage for offloading (or more, depending on how much storage you need to purchase). (Knowing the cost of DIY might help inform your decision on whether you should use a recovery service or not).
- b1jzcbxTutor
i'm thinking it's too late as well... it was a volume full of movies and shows for my plex server.. thankfully, my important docs and stuff (resumes, financials, etc...) had been backed up elsewhere, so..
it was kinda time for a spring cleaning, just didn't expect it to happen this way.. was about 6TB of movies and shows, most of which were collections that no one watched anyway.. oh well.. those drives are going into my truenas core box, so.. that just made the decision whether or not to buy new (used drives) or use those that much easier.. just a LOT of re-rendering and processing to do.. sucks..
