nigelivy
Sep 23, 2020Aspirant
Can't rebuild the volume on ReadyNAS NV+ v2
Hello! I'm having a problem with my ReadyNAS NV+ v2 in that I cannot restore to factory settings. I keep getting the error shown in the attached screenshot. I've tried taking all the drives out and ...
Marc_V
Sep 23, 2020NETGEAR Employee Retired
Welcome to the Community!
This is likely because of the drives not being supported by OS5. NV+ v2 can support up to 4TB drives while v1 up to 2TB only. Unfortunately, that is the limitation of the NV+v2. You may want to check the ReadyNAS HCL for compatible or tested drives.
HTH
nigelivy
Thanks for the input.
I've found this Netgear SOOOOO unstable that if I can't get this thing stable and if it infact can't handle more than 4tb drives, I'll be chucking it out and replacing it with something else. I'm so frustrated. I'm fast loosing faith in Netgear NAS products.
