jonas914
Aug 01, 2017Tutor
Can't register device to Replicate account??
I've had a pair of Pro4 NAS boxes using replicate (semi reliably) for awhile. I hade to delete a lot of files on one of them so I did a factory reset. I have since lost the ability to connect it to th...
Marty_M
Aug 02, 2017NETGEAR Employee Retired
Hello jonas914,
What version of Replicate addon are you using? Please try to remove and add back the replicate software on your NAS and check if that will make any difference. Your NAS is already running on the latest firmware version 4.2.30.
Marty_M
NETGEAR Community Team
jonas914
Aug 02, 2017Tutor
The app add on says 1.2. I've tried also manually downloading it.
- Apr 16, 2020Retired_Member
