jonas914
Aug 01, 2017Tutor
Can't register device to Replicate account??
I've had a pair of Pro4 NAS boxes using replicate (semi reliably) for awhile. I hade to delete a lot of files on one of them so I did a factory reset. I have since lost the ability to connect it to th...
Marty_M
Aug 02, 2017NETGEAR Employee Retired
Hello jonas914,
What version of Replicate addon are you using? Please try to remove and add back the replicate software on your NAS and check if that will make any difference. Your NAS is already running on the latest firmware version 4.2.30.
Marty_M
NETGEAR Community Team
Marty_M
Aug 03, 2017NETGEAR Employee Retired
Hello jonas914,
This specific NASis it connected to a network that is connected to a network that has internet access? Have you tried on a different web browser and clearing cache or using different computer in activating the license?
Marty_M
- jonas914Aug 03, 2017TutorIt's on the same network that was just working with it online in Replicate before I wiped it.
No, did not try another browser. It doesn't seem like that kind of error.- Marty_MAug 06, 2017NETGEAR Employee Retired
Hello jonas914,
For isolation please try a different web browser and clearing cache or using a different computer in activating the license?
Marty_M
NETGEAR Community Team - Marty_MAug 09, 2017NETGEAR Employee Retired
Hello jonas914,
We’d greatly appreciate hearing your feedback letting us know if the information we provided has helped resolve your issue or if you need further assistance. If your issue is now resolved, we encourage you to mark the appropriate reply as the “Accept as Solution” or post what resolved it and mark it as solution so others can be confident in benefiting from the solution.The Netgear community looks forward to hearing from you and being a helpful resource in the future!
Marty_M
NETGEAR Community Team- jonas914Aug 15, 2017Tutor
Okay, finally got around to testing other computers, other browsers, etc. It's not on my end. Same error no matter where I try it from.
Why is this broken?
- Apr 16, 2020Retired_Member
