miels
Oct 03, 2011Tutor
disable root ssh
I've recently installed the EnableRootSSH addon on my ReadyNas Ultra. I prefer to disable SSH when I don't need it, and I assumed I could disable root ssh access by just disabling / uninstalling the a...
mdgm-ntgr
Oct 20, 2011NETGEAR Employee Retired
Yes it will. However do note that support will still be able to tell that SSH has been enabled since the last factory reset and may deny support if you mucked things up using SSH.
Rather than disabling SSH it's better to set a strong password and to not expose port 22 (SSH port) on your NAS to the internet (i.e. don't port forward port 22 from your router to the NAS).
