miels
Oct 03, 2011Tutor
disable root ssh
I've recently installed the EnableRootSSH addon on my ReadyNas Ultra. I prefer to disable SSH when I don't need it, and I assumed I could disable root ssh access by just disabling / uninstalling the a...
mdgm-ntgr
Nov 17, 2011NETGEAR Employee Retired
Try using PuTTy (free program) on Windows. Select the SSH option and attempt to connect to the IP address of your NAS.
On Mac/Linux one would simply use the Terminal.
