TeknoJnky
Feb 04, 2012Hero
dropbox installer
does this addon automatically install the latest dropbox linux release, or only a particular version?
does the dropbox linux release update itself, or is it required to pay for another 'dropbox installer' ?
- AMRivlinApprenticePlease see this earlier post: posting.php?mode=reply&f=36&t=60941#pr349838
- mdgm-ntgrNETGEAR Employee RetiredHmmm. Sounds like for some reason Dropbox thinks it's linked to an account.
Can you do the following?:
MDGM-NAS:~# cat /c/.dropbox-dist/VERSION
MDGM-NAS:~# file /c/.dropbox-dist/* - mdgm-ntgrNETGEAR Employee RetiredPlease also do
MDGM-NAS:~# ps -ef | grep dropbox
which should give output something like this:
root 4748 14835 0 14:56 pts/0 00:00:00 grep dropbox
admin 17424 1 0 11:46 ? 00:00:00 /bin/bash /c/.dropbox-dist/run_dropbox.sh /c/.dropbox-dist/dropbox admin /c
admin 17427 17424 0 11:46 ? 00:00:21 /c/.dropbox-dist/dropbox - AMRivlinApprentice
AMRNAS:~# ps -ef | grep dropbox
admin 3519 1 0 21:47 ? 00:00:00 /bin/bash /c/.dropbox-dist/run_dropbox.sh /c/.dropbox-dist/dropbox admin /c
admin 3523 3519 0 21:47 ? 00:00:00 /c/.dropbox-dist/dropbox
root 8457 3451 0 22:00 pts/0 00:00:00 grep dropboxAMRNAS:~# at /c/.dropbox-dist/VERSION
syntax error. Last token seen: /
Garbled timeAMRNAS:~# file /c/.dropbox-dist/*
/c/.dropbox-dist/ACKNOWLEDGEMENTS: ASCII English text
/c/.dropbox-dist/array.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/binascii.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_bisect.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/bz2.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_cn.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_hk.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_iso2022.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_jp.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_kr.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_codecs_tw.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/collections.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/cPickle.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/cStringIO.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_ctypes.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/datetime.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_dbus_bindings.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_dbus_glib_bindings.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/dropbox: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.8, stripped
/c/.dropbox-dist/dropboxd: POSIX shell script text executable
/c/.dropbox-dist/fastpath.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/faulthandler.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/fcntl.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_functools.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/grp.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_heapq.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/icons: directory
/c/.dropbox-dist/itertools.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libbz2.so.1.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libcrypto.so.0.9.8: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libpng12.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libpopt.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/library.zip: ELF 32-bit LSB executable, Intel 80386, version 1 (SYSV), dynamically linked (uses shared libs), for GNU/Linux 2.6.8, stripped
/c/.dropbox-dist/_librsync.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/librsync.so.1: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libssl.so.0.9.8: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libstdc++.so.6: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_baseud-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_baseud_net-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_baseud_xml-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_gtk2ud_adv-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_gtk2ud_core-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libwx_gtk2ud_qa-2.8.so.0: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/libz.so.1: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_locale.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_lsprof.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/math.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_multibytecodec.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/netifaces-0.5-py2.5-linux-i686.egg: directory
/c/.dropbox-dist/operator.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/parser.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/pyexpat.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_random.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/README: ASCII English text
/c/.dropbox-dist/resource.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/run_dropbox.sh: Bourne-Again shell script text executable
/c/.dropbox-dist/running: empty
/c/.dropbox-dist/select.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/setuptools-0.6c11-py2.5.egg: Zip archive data, at least v2.0 to extract
/c/.dropbox-dist/_speedups.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/strop.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/_struct.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/termios.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/time.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/unicodedata.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/VERSION: ASCII text, with no line terminators
/c/.dropbox-dist/_weakref.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._controls_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._core_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._gdi_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._misc_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped
/c/.dropbox-dist/wx._windows_.so: ELF 32-bit LSB shared object, Intel 80386, version 1 (SYSV), dynamically linked, stripped - mdgm-ntgrNETGEAR Employee RetiredYou need to do "cat" not "at". They are different commands.
What version of RAIDiator are you running?
Have you tried rebooting the NAS to see if that makes a difference? - AMRivlinApprentice
AMRNAS:~# cat /c/.dropbox-dist/VERSION
1.2.52AMRNAS:~#
I rebooted, no change. - can you post a screenshot of the addons page dropbox config ?
- mdgm-ntgrNETGEAR Employee RetiredWhat version of RAIDiator is on your unit?
MDGM-NAS:~# cat /var/log/raidiator_version
Do you have any other add-ons installed?
Can check via
MDGM-NAS:~# cat /etc/frontview/addons/addons.conf
and
MDGM-NAS:~# cat /etc/default/services - AMRivlinApprentice
AMRNAS:~# cat /var/log/raidiator_version
RAIDiator!!version=4.2.19,time=1314659067AMRNAS:~# cat /etc/frontview/addons/addons.conf
DAAPD!!FireFly!!1.0.0!!
TRANSMISSION!!Transmission!!2.50.02!!
READYNAS_PHOTOS_II!!II!!1.0.6!!
READYNASREMOTE!!ReadyNAS Remote!!1.0.9.78!!
PYTHON2_6!!Python2.6!!2.6.6-rnx86-0.3.2!!
SABNZBD!!SABnzbd!!0.6.15-rnx86-0.7.0!!
SICKBEARD!!SickBeard!!0.493.1-rnx86-0.9.3!!
PHP5!!PHP5!!5.3.10-rnx86-4.1.2!!
PLEXMEDIASERVER!!PlexMediaServer!!0.9.6.0.11-ba33da9-x86!!
DROPBOX!!DropBox!!Install-rnx86-0.9.7!!/etc/frontview/addons/bin/DROPBOX/start.sh!!/etc/frontview/addons/bin/DROPBOX/stop.sh!!Other!!current_url==http://readynasxtras.com/addons/x86/xml/DROPBOX_CURRENT.xml::detail_url==http://readynasxtras.com/readynas-x86-add-ons/dropbox-x86::icon_url==/addons/DROPBOX/dropbox_logo.gifAMRNAS:~# cat /etc/default/services
APACHE=0
APACHESSL=1
ATALKD=0
AUTOMATIC_VOLUME_EXPANSION=1
AUTO_CHECK_UPDATE=1
BONJOUR=1
BONJOUR_AFP=1
BONJOUR_FRONTVIEW=1
BONJOUR_PRINTER=1
BONJOUR_SUPPORT=1
CSV_USERADD_SUPPORT=1
DAAPD=0
DAAPD_SUPPORT=1
DISKCACHE=1
DOMAIN_SUPPORT=1
ENABLE_POWERON_TIMER_SUPPORT=1
ENCODE=utf-8
FAN=1,1,0,0,0
FLASH_AUTO_COPY=0
FLASH_OWNER=admin
FLASH_PATH=Pictures
FLASH_SHARE=media
FTP_MASQUERADE_ADDRESS=AMRNAS
FTP_MODE=anonymous
FTP_PASSIVE_END=65535
FTP_PASSIVE_START=1024
FTP_PORT=21
FTP_UPLOAD_RESUME=0
HTTPS_SSL_KEY_HOST=192.168.1.75
IPV6_ASSIGN_bond0=OFF
IPV6_ASSIGN_eth0=OFF
JOURNAL=ordered
JUMBO_FRAMES_bond0=0
JUMBO_FRAMES_eth0=0
LANGUAGE=en-us
LANGUAGES_SUPPORTED=en-us/utf-8,en-us/ascii,ja/euc-jp,ko/euc-kr,ja/utf-8,ko/utf-8,zh-cn/utf-8,zh-tw/utf-8,ru/utf-8,es/utf-8,pt/utf-8,de/utf-8,fr/utf-8,it/utf-8,nl/utf-8,pl/utf-8,cs/utf-8,hu/utf-8,nb/utf-8,da/utf-8,fi/utf-8,sv/utf-8
MONITOR=board_temp,fan,disk_full,quota_exceeded,disk_temp
NETATALK=1
NFS=0
NTPDATE=1
PROFTPD=0
RAID_MODE=1
READYNASREMOTE=1
READYNASREMOTE_SUPPORT=1
READYNAS_PHOTOS_II=0
READYNAS_PHOTOS_II_SUPPORT=1
READYTIVOD=0
RESYNC_UNCLEAN_SHUTDOWN=1
RSYNC=0
RSYNC_SUPPORT=1
SAMBA=1
SHAREACCESS=SAMBA,NETATALK
SHUTDOWN_ON_DISK_OVERTEMP=1
SMTP_PROVIDER=Gmail
SNMP=1
SNMP_COMMUNITY=public
SNMP_SUPPORT=1
SPEED_DUPLEX_eth0=AUTO_NEGOTIATION
SSH=1
SSHKEY=rsa
SUPPORT_UTF8_NAMES=1
TEMP=1,1,0
TRANSMISSION=1
TRANSMISSION_PORT=8181
TRANSMISSION_SUPPORT=1
UDHCPD=0
UPNP=1
UPNPAV=0
UPNPAV_SUPPORT=1
UPNP_SUPPORT=1
USER_HOME_DIRECTORY=1
WINBIND=0
WIZD=0
WIZD_SUPPORT=0
PYTHON2_6_SUPPORT=1
PYTHON2_6=1
SABNZBD_SUPPORT=1
SABNZBD=1
SICKBEARD_SUPPORT=1
SICKBEARD=1
PHP5_SUPPORT=1
PHP5=1
PLEXMEDIASERVER_SUPPORT=1
PLEXMEDIASERVER=1
DROPBOX_SUPPORT=1
DROPBOX=1
AMRNAS:~# - mdgm-ntgrNETGEAR Employee RetiredCould you try re-installing the Dropbox add-on over the top of itself and see if that helps?
