Patrick123
Aug 22, 2018Aspirant
Firmware updating ReadyNas NV+
Hello,
I have
Model:
Infrant ReadyNAS NV+
Serial:
Firmware:
RAIDiatorâ„¢ v3.01c1-p6 [1.00a034]
Currently having connecting issue ...
Aug 22, 2018Guru - Experienced User
Wow. 2006 firmware.
This post should help you: https://community.netgear.com/t5/Using-your-ReadyNAS/Firmware-Upgrade-to-ReadyNAS-NV/m-p/928289#M68513
You will likely need an old browser to access the NAS, and as you'll see in the post you should update to 4.1.8 first, and then 4.1.16.
The default admin password of your NAS is probably infrant1. Newer firmware would use netgear1.
4.1.8 is here: http://www.readynas.com/download/RAIDiator/archive/4.1.8/RAIDiator-4.1.8
4.1.16 is here: https://kb.netgear.com/000038792/RAIDiator-Version-4-1-16-Sparc
Patrick123
Aug 25, 2018Aspirant
Hello,
I'm having trouble with the link for 4.1.8 doesn't seem to download or go to a correct page. do you have a different location?
thanks,
- bedlam1Aug 25, 2018Prodigy
That link works perfectly using Google Chrome
