pvdwaal
Jul 08, 2011Aspirant
Help with NZB Apps
I own a ReadyNAS RNDU4000 with 4x2TB Samsung drives, RAIDiator 4.2.17 As far as I know I have two options for NZB: - NZBGet - SabNZBd I tried NZBGet and it downloaded with my full internet ba...
Laurensvh
Jul 13, 2011Aspirant
@ vuilverwerking
I already managed to get the right php addon and also nzbget is working properly in terms of downloading
In terms of parring and extracting I don't get any error unfortunately. In the log I see start postprocess and at the exact same timestamp it says finished postprocess.
I used the exact same directories as seen in the manual and changed the permissions with Putty. Checked it after that with the ls -l command and everything looks fine.
