pvdwaal
Jul 08, 2011Aspirant
Help with NZB Apps
I own a ReadyNAS RNDU4000 with 4x2TB Samsung drives, RAIDiator 4.2.17 As far as I know I have two options for NZB: - NZBGet - SabNZBd I tried NZBGet and it downloaded with my full internet ba...
vuilverwerking1
Jul 13, 2011Aspirant
Don't forget to shutdown the NZBGet addon before doing any changes.
You have to restart if you change anything in the configuration.
You also need unrar and par2 packages. You can install those via SSH. You need SSH access (and apt-get addons)*, which you can get at the follow locations.
http://www.readynas.com/download/addons ... SH_1.0.bin
http://www.readynas.com/download/addons ... PT_1.0.bin *
* -APT_1.0.bin does not work on NVX's
apt-get update
apt-get install par2
apt-get install unrar
