joeho717
Oct 10, 2008Aspirant
how to add no-ip client to ReadyNAS ?
There is a Linux/BSD/Unix version of the client, and I was hoping to add that to my ReadyNAS Duo at work. I have enabled SSH for the Duo, does anyone have this up and running and can provide some inst...
a_carneiro
Oct 10, 2008Tutor
For your information, you'll need a bit of tweaking with the config files so you'll have to get SSH access to the unit in order to make it work.
But I've got it running on my two NV+s and it's working just fine :)
