joeho717
Oct 10, 2008Aspirant
how to add no-ip client to ReadyNAS ?
There is a Linux/BSD/Unix version of the client, and I was hoping to add that to my ReadyNAS Duo at work. I have enabled SSH for the Duo, does anyone have this up and running and can provide some inst...
a_carneiro
Oct 15, 2008Tutor
joeho717 wrote: thank you for both of your replies. Can you post the steps on how to make it work ? or the add-on ?
:D :D appreciate your help
Super-Poussin will have to post the link to the addon.
How comfortable are you with SSHing to the box?
