joeho717
Oct 10, 2008Aspirant
how to add no-ip client to ReadyNAS ?
There is a Linux/BSD/Unix version of the client, and I was hoping to add that to my ReadyNAS Duo at work. I have enabled SSH for the Duo, does anyone have this up and running and can provide some inst...
Palinus
Oct 26, 2008Aspirant
I've just installed the add-on, but I I cannot use it.
I wrote my datas in the GUI parameters: "-u MYNOIPEMAIL -p MYNOIPPASSWORD -U 30".
When I try to activate it a window says: "NOIP service failed to start.".
Is there something else to configure?
Thank you,
Palinus
Thank you,
Palinus
