joeho717
Oct 10, 2008Aspirant
how to add no-ip client to ReadyNAS ?
There is a Linux/BSD/Unix version of the client, and I was hoping to add that to my ReadyNAS Duo at work. I have enabled SSH for the Duo, does anyone have this up and running and can provide some inst...
super_poussin
Dec 06, 2008Virtuoso
try to reboot :) the it should be ok
I understand the security concern I can make it replace letters by . but it will not be easy to check if everything is ok before apply
