joeho717
Oct 10, 2008Aspirant
how to add no-ip client to ReadyNAS ?
There is a Linux/BSD/Unix version of the client, and I was hoping to add that to my ReadyNAS Duo at work. I have enabled SSH for the Duo, does anyone have this up and running and can provide some inst...
rmfield
Dec 06, 2008Aspirant
I can view the no-ip.log and every time I disable and enable the addon, it adds a couple of lines about creating the config file.
Still the only way to check the status with no-ip -S is by copying the config file to /usr/local/etc, even after a reboot.
