joeho717
Oct 10, 2008Aspirant
how to add no-ip client to ReadyNAS ?
There is a Linux/BSD/Unix version of the client, and I was hoping to add that to my ReadyNAS Duo at work. I have enabled SSH for the Duo, does anyone have this up and running and can provide some inst...
faidit
Mar 03, 2009Aspirant
I have installed noip 1.1 as a local image in the system menu.
It appears a no-ip.log file into media witch says :
Can't locate configuration file /usr/local/etc/no-ip2.conf. (Try -c). Ending!
What can I do ?
What can I do ?
