joeho717
Oct 10, 2008Aspirant
how to add no-ip client to ReadyNAS ?
There is a Linux/BSD/Unix version of the client, and I was hoping to add that to my ReadyNAS Duo at work. I have enabled SSH for the Duo, does anyone have this up and running and can provide some inst...
eton
Jan 27, 2013Luminary
No-IP is just a mess. I don't use their services nor the client anymore.
But for your information here is an old log file from the no-ip client. Off course it didn't work for me either.
Instead I would reccomend WhoCares DDclient and some other service than No-IP.
Check out my research here: viewtopic.php?f=36&t=62612
Can't locate configuration file /usr/local/etc/no-ip2.conf. (Try -c). Ending!
USAGE: no-ip [ -C [ -F][ -Y][ -U #min]
[ -u username][ -p password][ -x progname]]
[ -c file][ -d][ -D pid][ -i addr][ -S][ -M][ -h]
Version Linux-2.1.9
Options: -C create configuration data
-F force NAT off
-Y select all hosts/groups
-U minutes set update interval
-u username use supplied username
-p password use supplied password
-x executable use supplied executable
-c config_file use alternate data path
-d increase debug verbosity
-D processID toggle debug flag for PID
-i IPaddress use supplied address
-I interface use supplied interface
-S show configuration data
-M permit multiple instances
-K processID terminate instance PID
-z activate shm dump code
-h help (this text)
Configuration file '/etc/no-ip2.conf' is in use by process 1287.
Ending!
One no-ip process is already active,
and the multiple instance flag (-M) is not set.
Auto configuration for Linux client of no-ip.com.
Multiple network devices have been detected.
Please select the Internet interface from this list.
By typing the number associated with it.
0 eth0
1 LeafNets
You have entered an incorrect username
-or-
an incorrect password for this username.
Version Linux-2.1.9
-F force NAT off
-h help (this text)
0 eth0
1 LeafNets
Only one host [stilarkivet.myftp.org] is registered to this account.
It will be used.
New configuration file '/etc/no-ip2.conf' created.
0 eth0
1 LeafNets
-or-
Version Linux-2.1.9
-F force NAT off
-h help (this text)
0 eth0
1 LeafNets
It will be used.
It will be used.
Configuration file '/etc/no-ip2.conf' is in use by process 1772.
Ending!
