beefy314
Jul 20, 2011Aspirant
How to change download location on Transmission?
I have a ReadyNAS ultra 2 with 2 different hard drives running as separate volumes (c and d) I have the 2.31 x86 running on volume C. The default download directory is /c/media/BitTorrent. I tried ...
de_niro
Jul 21, 2011Guide
First you need install root-ssh addon to login unit with default password to edit
/addons-config/Transmission/transmission-daemon/settings.json file
in this file you can customize directory of complete and incomplete download folder.
Before you edit this file please disable transmisson service.
