beefy314
Jul 20, 2011Aspirant
How to change download location on Transmission?
I have a ReadyNAS ultra 2 with 2 different hard drives running as separate volumes (c and d) I have the 2.31 x86 running on volume C. The default download directory is /c/media/BitTorrent. I tried ...
Sleepy81
Jul 26, 2011Aspirant
I have the same problem...
I have a ReadyNas Ultra 4 and a share called "TorrentFiles" with a "Finished" subfolder
I have tried to use the GUI and entered /C/TorrenFiles/Finished, \\READYNAS\TorrentFiles\Finished and /TorrenFiles/Finished, and nothing works. Also tried to modify the settings.json file (with Transmission disabled) but stilln no luck...
I'm new to the world of NAS, so just to make sure how it is supposed to be, what is the correct syntax used when describing shares/folders on a ReadyNas Ultra drive?
