ScottChapman
Jan 26, 2014Apprentice
how to configure iStat on OS6?
I got iSTat installed and running. But launch button is not active.
It does day what port to use, and what the default password, question is, what is the URL?
I tried http://<NAS>:5109 but get a "null" back.
- doylmiGuide
doylmi wrote: I'll make sure this is clearer in the next iteration. Will probably prompt for the passcode iStat is detected, but the passcode is missing.
This has been implemented.- ReadyASGuide
I will describe my case I had on RNDP4000 with OS6:
The stat daemon did not started, so I tried to run it manualy:
root@nas:/apps/istat/bin# ./istatd
and I saw the message:
"Could not read configuration from /usr/local/etc/istat.conf: No such file or directory
root@nas:/apps/istat/bin# more istatd"So I copied istat.conf:
root@nas:/apps/istat/bin# cp -p /etc/istat.conf /usr/local/etc/
Since this time there was not problem tu run the stat daemon from UI using ON/OFF switch, but still the main RUN button is inactive.
Iteresting that:
"root@nas:/apps/istat/bin# ps -ef|grep istat
admin 18717 1 0 18:45 ? 00:00:00 /apps/istat/bin/istatd -d -c /etc/istat.conf"I mean "/etc/istat.conf" is as a parameter and "/usr/local/etc/istat.conf" is used in reality? Is the second path hardcoded?
- ScottChapmanApprentice
doylmi wrote: How'd it go? :)
Got it. THanks! - doylmiGuideHow'd it go? :)
- super_poussinVirtuosoYep that's 12345 by default as written on the frontview interface
- doylmiGuideI can't comment on the share, but the "default password" that displays on the Apps tab is the passcode. I believe this is 12345. super-poussin is the maintainer for the iStat "app" for ReadyNAS if you have questions specifically regarding iStat.
doylmi wrote: ScottChapman wrote: It's free on the android. But my experience is above... No idea not to establish my "passcode"
Or stated different, there is no charge for the one I can't get to work! ;-)
No problem, please use the following steps:
[list=a:3ls9fup8]- Go to the main screen (the one that lists your NAS device(s)).
- Press and hold your finger on the one you want to update the passcode for.
- Click "Edit" when the context menu pops up
- Scroll to the bottom, and update the passcode
- Press save
Also, when I installed iStat on my NAS, I got a share (that appears to be empty) than is snapshotting ever hour. - ScottChapmanApprentice
[list=a:3c0klogw]- Go to the main screen (the one that lists your NAS device(s)).
- Press save
So, I see how to enter my passcode, but my question was really what is my passcode??? I do not know how to establish or otherwise determine what my passcode is... - doylmiGuideYes, I am.
- ScottChapmanApprenticeOK, I'll try that. Are you the author of the android app?
- doylmiGuide
[list=a:3hvn35tz]- Go to the main screen (the one that lists your NAS device(s)).
- Press save
