daveswee
Mar 25, 2025Follower
How to transfer a folder from my PC to my ReadyNAS
Hi,
I'm trying to transfer folders (not just files) from my PC to my ReadyNAS RN204 storage device using the web interface. I can see how to transfer files but not folders. I haven't been able to map the ReadyNAS to my PC using its IP address so I need to use the web interface. How do I transfer folders using the web interface?
Thanks.
Dave
P.S. This is my first-ever post here so I apologize if I'm not using this resource correctly.
How are you trying to do this?
Assuming a Windows PC ...
You can try this test:
- If you are using the default admin password (password) then change it to something else.
- Open CMD from Windows and then enter:
net use * /d /y net use z: \\nas-ip-address\data /u:admin nas-admin-passwordreplacing "nas-ip-address" and "nas-admin-password" with the real values of course.
The second command should mount the full data volume as drive letter z.
If this test works, then you can try creating a user account on the NAS. Then enter the credentials (username and password) for the account in the Windows Credential manager.
After that you should be able to access the NAS with file explorer by entering \\nas-ip-address in the address bar. You can also map individual shares to drive letters. But mapping the full data volume requires using the NAS admin credentials.
- taceto12Apprentice
Welcome, I'm fairly new here myself and can tell you this is the right place to ask questions about the ReadyNAS. There are tons of very smart, kind and helpful people here!
I'm curious to understand why you can't mount your NAS to your PC.
My first question: What version of OS are you running on the PC and the RN204?
I'm running OS6.10.10 on both my ReadyNAS boxes and haven't found any way to transfer folders (or files for that matter) using just the NAS web interface. I can see where you can create a new folder using the web page though. Have you tried creating a new folder on the NAS with the same name then transferring your files into the new folder?
How did you transfer files from your PC to your ReadyNAS using just the NAS web interface? Did you use a ReadyNAS addon app?
At the end of the day I suppose you could just copy your folder(s) and files onto a USB stick, plug it into the USB port on the NAS and transfer the data from the USB stick to the NAS. This link might help if you're running OS6:
https://kb.netgear.com/7015/Copying-files-from-USB-drive-to-ReadyNAS-OS6
Let us know and again, welcome!
OK, missed the file upload button on the web page, my bad.... so not sure why you can't create a folder on the NAS with the same name as the one you're copying files from on your PC and upload the files into that folder
