KDMcm
Jul 12, 2026Aspirant
Identifying my Unit and Reviving it
I'm trying to identify what unit I have. On the front panel, it says "ReadyNAS Duo" (no version number). On the underside label, it says "ReadyNAS Duo RND2000 v2". I can see that this has been a ...
- Jul 30, 2026
KDMcm wrote:
when I use / admin, I get the SSL error.
Use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).
After set up, you can also enable ssh and make a mod to one of the config files that lets you connect with http (unencrypted, but works with any browser).
saudade
Jul 16, 2026Apprentice
Like Stephen says, it's a V1. I also have a V1. Instead of "192.168.1.117/shares", use http://<ipaddress>/admin. Post back if you get an SSL error.
4.1.16 is the latest (last) firmware.
Max drive size is 2 TB. Depending on how you plan to use it, you could mirror the pair for 2TB storage, or stripe the pair for 4TB storage but no redundancy.
I use mine to backup another NAS (different brand) so I have the drives mirrored.
