KDMcm
Jul 12, 2026Aspirant
Identifying my Unit and Reviving it
I'm trying to identify what unit I have. On the front panel, it says "ReadyNAS Duo" (no version number). On the underside label, it says "ReadyNAS Duo RND2000 v2". I can see that this has been a ...
- Jul 30, 2026
KDMcm wrote:
when I use / admin, I get the SSL error.
Use Firefox, and set security.tls.version.min to 1 (browse to about:config and search for the setting).
After set up, you can also enable ssh and make a mod to one of the config files that lets you connect with http (unencrypted, but works with any browser).
KDMcm
Jul 30, 2026Aspirant
Finally getting back to this. Yes, when I use / admin, I get the SSL error.
In the hopes that it was simply in need of some drives it could cope with, I have now replaced those with 2x 1Tb drives.
I went through the factory restore process, RAIDar reported for quite some time that it was Synching. It stayed at 0.0% for about 2 hours and then suddenly changed to "Healthy."
saudade StephenB any thoughts on how I can progess, please? ChatGPT seems to thin that an elderly browser won't necessarily help, but my thinking is: it USED to work...
- StephenBJul 30, 2026Guru - Experienced User
- KDMcmJul 30, 2026Aspirant
Did the Firefox thing and now have a very much more useful interface.
Can you please help me locate the setting for unencrypted HTTP? I'm not seeing it.Thank you.
No setting for it. You need to modify one of the config files.
Details are here:
- https://community.netgear.com/discussions/readynas-general/workaround-for-err-ssl-version-or-cipher-mismatch-problem-for-sparc-nas-4-1-x-fi/2198243
