tompijls
Jun 17, 2012Aspirant
Issue when removing Airvideo
Hi, I installed the AirVideo add-on on a net gear ReadyNAS Ultra 6 with firmware 4.2.21. I decided to remove it, but now when my HDX media player tries to connect to my net gear/media folder, it on...
Jun 17, 2012Guru - Experienced User
You might need to consult your HDX users guide. The HDX BD1 supports CIFS and NFS, so it should be able to directly access your shares. You can also try ReadyDLNA.
