tompijls
Jun 17, 2012Aspirant
Issue when removing Airvideo
Hi, I installed the AirVideo add-on on a net gear ReadyNAS Ultra 6 with firmware 4.2.21. I decided to remove it, but now when my HDX media player tries to connect to my net gear/media folder, it on...
tompijls
Jun 18, 2012Aspirant
Thanks,
the problem is it does connect, and shows to Folders; only it does not show the data folders which contain my media files (and which show up on my mac), but only the folders which were created for AirVideo. Seems the uninstall from the AirVideo plugin did not fully restore the systems to it's defaults
