tompijls
Jun 17, 2012Aspirant
Issue when removing Airvideo
Hi, I installed the AirVideo add-on on a net gear ReadyNAS Ultra 6 with firmware 4.2.21. I decided to remove it, but now when my HDX media player tries to connect to my net gear/media folder, it on...
mdgm-ntgr
Jun 19, 2012NETGEAR Employee Retired
This is a variant of an issue seen on previous firmware emerging again.
Do you have SSH access? If so the best way to fix this issue would be using that. Using "vi" to modify that file to fix it and also modifying config files for other protocols that use the media share if their configuration has been mucked up as well.
If not, you could try renaming the media share under Shares > Share Listing, clicking apply, then renaming it back. Don't try anything else to "fix" the issue. Doing the wrong thing can lead to data loss.
If renaming the share doesn't fix the problem then remote access will be needed to your NAS to fix the issue.
