tompijls
Jun 17, 2012Aspirant
Issue when removing Airvideo
Hi, I installed the AirVideo add-on on a net gear ReadyNAS Ultra 6 with firmware 4.2.21. I decided to remove it, but now when my HDX media player tries to connect to my net gear/media folder, it on...
mdgm-ntgr
Jun 20, 2012NETGEAR Employee Retired
For remote access you would put the NAS in tech support mode (http://www.readynas.com/kb/faq/boot/how_do_i_use_the_boot_menu), forward port 23 to the NAS and let tech support know your IP.
This is a different issue I think to another one that was fixed in a previous firmware update but with some of the same symptoms.
