kcallis
Dec 12, 2012Aspirant
Issues with the Sickbeard Update on NV+
I just bought the latest, greatest update of Sickbeard from the Add-On Xtras. I was happy the see the alpha version ask to update to the latest version of Sickbeard. I hit the update button and though...
gibxxi
Dec 13, 2012Guide
When an update is available you ought to get a notification in the lower right hand side of the screen saying so, and by how many "commits" you are "behind". Like CouchPotato V1, many commits may be pushed to the GIT repository at the same time, so if it says your 15 commits behind, that doesn't mean you've missed 15 prior updates. It means the author of the mod (or a member of his team) have pushed 15 changes to the repository.
Currently, Neither Sickbeard or Headphones update themselves, whereas the new version of CouchPotato - V2 (otherwise known as CouchPotatoServer) can and does update itself and automatically apply the changes without need for user interaction (It does still notify you that changes have been applied though).
