kcallis
Dec 12, 2012Aspirant
Issues with the Sickbeard Update on NV+
I just bought the latest, greatest update of Sickbeard from the Add-On Xtras. I was happy the see the alpha version ask to update to the latest version of Sickbeard. I hit the update button and though...
gibxxi
Dec 13, 2012Guide
The "days retention" value may be why it's not pulling some items. You will want to check this value both in SB and SABNZBD+ and set it to the retention value of your usenet provider.
NZB.su isn't working for me, I did have an account on there, but they seemed to have shut up shop too. I, like you used NZBMatrix primarily. NZBsRus seems to be the best alternative, but it's currently limited to VIP users, and that requires setting up bitcoin, which I'd rather not have to mess about with at this time.
It seems that NZB.su is redirecting to Usenet-Crawler.com for me, may try this going forwards (Another site that's based on the NewzNAB code). You can also enable the Sickbeard Indexer, although as it says in the app, it doesn't currently support backlog searches. So i'm guessing any shows added with only this indexer available will not get any old episodes pulled, but will get future episodes pulled, as they are posted.
I'd also set Sab's Post-Processing Scripts Folder to:
Then you can create a category in Sab that will use the post process script, and use the same category name in Sickbeard so that there is two-way communication between the two apps and your downloaded TV shows are both moved to the correct folder, and formatted with the required filename. There is a thread about this somewhere (either on this site, or ReadyNASXtras.com).
/c/.sickbeard/autoProcessTV
