kcallis
Dec 12, 2012Aspirant
Issues with the Sickbeard Update on NV+
I just bought the latest, greatest update of Sickbeard from the Add-On Xtras. I was happy the see the alpha version ask to update to the latest version of Sickbeard. I hit the update button and though...
gibxxi
Dec 13, 2012Guide
Another thing I've noticed with all these types of search App (CouchPotato, SickBeard, HeadPhones) when I was using them in conjunction with NZBMatrix was the format of the NZB title as posted to usenet was important. If the title of the Usenet post (as uploaded by the poster) doesn't conform to the result of the regex search these apps are using EXACTLY, it will be ignored. Also, sometimes they'll pull content that's not exactly what you were after, for the same reason.
There's not a lot that can be done about this unless Usenet posters all start uploading and titleing their posts in a way that conforms to these apps. Not out of the realms of possibility, after all, compared to the age of the usenet in general, these apps have only been around a VERY short time. But It may take a while, if it happens at all.
The other caveat is that SB sometimes skips a series if the whole series is in one NZB, as a pose to single episodes being uploaded as single NZB's. Add the regex algorithm conundrum to this list, and you will get a situation like the one your experiencing.
