brianaker
Feb 27, 2019Aspirant
LogAnalyzer package download?
Where can I obtain a copy of the LogAnalyzer package?
I had to reinstall my Readynas and it seems that the package no longer appears on the Apps page. Thanks!
brianaker
I was looking for a package for 6.x.
Sorry if I posted in the wrong forum, I assumed "old" meant, "no longer shipped with".
Unrelated though, I do though still have a 4.x 'Nas that I only spin up if I need to look at a very old backup. It is a decade old and still works :)
Feb 28, 2019Guru - Experienced User
There were a lot of issues reported here with the OS 6 package. It wrote the log information to the OS partition, and that often filled the partition (resulting in a loss of access of the web ui, damaged share configurations, etc). I'm not seeing a notice here on when it was taken down, and it might not be compatible with current firmware.
You can still find the download via wayback.com but I don't recommend using it.
- brianakerFeb 28, 2019Aspirant
Any hints on what the URL would be?
I have been using LogAnalyzer on ReadyNas for years. I am unsurprised to hear that the default package would fill a partition ( well, sort of... that would have required changing the default rsyslog setup ).
If there is a repository for the package I can provide details either there ( or via reply on this comment ) on what you need to change to make it scale. I personally have rsyslog stick its data in MySQL and then have LogAnalyzer read the data from the tables rsyslog creates in the database. I do point the base data tables from MySQL write to share and not to /var/lib/mysql ( which really should be obvious and the default for anyone using a database on a ReadyNAS ). LogAnalyzer will then just read the data from MySQL.
I would recommend you take a second at look at LogAnalyzer on ReadyNAS, it is a nice compact solution which scales well for any home/small business use case.- StephenBMar 01, 2019Guru - Experienced User
https://web.archive.org/web/20170420232406/https://apps.readynas.com/pages/?page_id=9 is the 2017-04-20 version of the app page. The download link for loganalyzer on that archived page still works.
- gbeddowApr 29, 2019Luminary
The download link doesn't work.
Does anyone know where I can find the LogAnalyzer download package? This is for an RN202 running OS 6.10.0. Thanks!
