kupermanp
Oct 24, 2010Aspirant
mySQL questions for XBMC database
Hi, I'm running a readynas NV+ and a Pro pioneer which serve as storage for acer 1600 HTPC's which act as media streamers using XBMC. I'm trying to syncronize my XBMC database so that I can watch...
sphardy1
Oct 08, 2011Apprentice
Probably the mysql config is restricted to not accept network connections - by default it will only accept connections from applications running on the same server.
You'll have to update the mysql config and restart the server
