davidpw
Apr 03, 2012Aspirant
NASMON and LoadAvg
I seem to be having the same problem tht some others have reported in the forum. The other modules work fine, however when I try to launch LoadAvg I get an error from the browser window:
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
IE does not work either.
Is there a solution to this?
David
David
- AMRivlinApprenticeI had a lot of problems with these addons, I no longer use them, because there seems to be no one officially supporting them.
- dsm1212ApprenticeThey don't work if you are using https to access your nas. I did manage to modify the php files and get them to work, but i'm not sure I can distribute the edits. I haven't installed the latest version because I don't want to re-figure out the edits to make this work again.
steve - EtzAspirantRead this topic: viewtopic.php?f=61&t=50985
- davidpwAspirantEtz: thanks for the pointer. I did read that thread but it seemed very unclear as to the fix and if it actually fixed all the issues.
BTW I am running on a ReadyNAS Pro and I have load the latest version of NASMON. The thread seemed to imply that the latest version may have helped.
OH well - may just stick with the other 3 modules.
David - davidpwAspirantwell - I made the following changes as listed in Etz post:
changed off to on in the "allow anyone"
and
added the secure_conn line.
This fixed the graphs, but the other modules within loadavg still do not work for me. Still the graphs make me feel better!
Thanks Etz.
David - dsm1212ApprenticeEverything seems to work for me unless there is something outright missing that I don't know about :-), but I don't know what PHP edits I made when I last installed it and I'm not running the latest version. What is it that doesn't populate? The stuff under the Server tab?
steve - dsm1212ApprenticeI looked through all 4 modules and what I see wrong is: 1) loadavg timezone is incorrect so 0 on the graph his not midnight. 2) no smart info on the phpsysinfo page. 3) processes listed on the phpsysinfo page are odd. explorer.exe??? They must be hardcoded somewhere.
Otherwise looks pretty accurate.
BTW I'm using Whocares php addon (not the very latest, the prior version). Maybe the issues are really with Super's PHP addon?
steve - davidpwAspirantHi steve,
server button still gives the error from the browser:
The times in LOADAVG appear to be GMT.
David - dsm1212ApprenticeServer button works for me. Weird, but I did edit the scripits to get them working with https, so maybe it was something I changed.
- SandsharkSensei
dsm1212 wrote: I looked through all 4 modules and what I see wrong is: 1) loadavg timezone is incorrect so 0 on the graph his not midnight. 2) no smart info on the phpsysinfo page. 3) processes listed on the phpsysinfo page are odd. explorer.exe??? They must be hardcoded somewhere.
steve
You have to set the correct timezone in PHP.INI. It's at the bottom. When you edit from within FrontView, the SAVE button is almost unseen to the right of the Cancel button. You can find your correct PHP timezone here: http://us2.php.net/manual/en/timezones.php.
