aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
aresgodofwar30
Mar 11, 2010Aspirant
Turns out the libxml automatic requires is newer than what can be installed on the duo. With the help of the developer I modified configure.in to require a lesser version but when running autoreconf command it complains some more about not being able to find perl
I checked the paths I have set and perl is there.
I'll have to get with the developer again and see if he can give me more assistance.
