aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
super_poussin
Mar 11, 2010Virtuoso
aresgodofwar30 wrote: Turns out the libxml automatic requires is newer than what can be installed on the duo. With the help of the developer I modified configure.in to require a lesser version but when running autoreconf command it complains some more about not being able to find perl
I checked the paths I have set and perl is there.
I'll have to get with the developer again and see if he can give me more assistance.
BTW do not upgrade perl or you will loose frontview
