aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
mdgm-ntgr
Mar 12, 2010NETGEAR Employee Retired
aresgodofwar30 wrote: are you saying that the devs have dropped work on the duo and are unwilling to do any updates?
No. But the base firmware that the Sparc firmware uses is quite old. So updating some things to the latest version would require rebuilding the firmware from scratch or porting the incompatible update so it can work with the rest of the Sparc firmware. These things take time and NetGear would have to prioritise what they work on.
