aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
Trial_Master
Mar 19, 2010Aspirant
mdgm wrote:
aresgodofwar30 wrote: maybe netgear should think about updating the duo line with an x86 processor and do away with the sparc line.
They probably will eventually. Though even when such a NAS is still released the price of the Duo will probably be lower enough for some to still find it attractive.
Trial_Master wrote: If they ever develop the option to take HDD's out of Sparc and drop them into a Pro I'd sell my NV+ tomorrow. Otherwise I don't have enough storage space to move my data too.
How much data do you have? You do realise you can buy hdds and put them in the Pro and transfer the data from the NV+ to the Pro over your network?
That will probably be the way I do it. I currently have 4 x 1TB drives so when they hit capacity instead of upgrading the HDD's for NV+ I'll purchase a Pro and move everything across then sell the NV+. It would be nice to be able to migrate the data across from one platform to the other to avoid the additional cost though.
