aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
WhoCares_
May 14, 2010Mentor
Trial_Master wrote: Stefan you are a legend! I'm keen to install this but just want to confirm (as per post 2 in this thread) that I won't kill Frontview.
In my world, a killed/crashed Frontview does not look like this:
You didn't really think that I'd knowingly release an add-on that would kill Frontview, did you? ;)
The only thing (with the Sparc version only) is that when you run automatic from the command line it will complain about a missing version information on the libcurl.so. That's a known bug of the specific version of libcurl installed on the ReadyNAS Sparc line and to my knowledge doesn't affect functionality.
-Stefan
