aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
Trial_Master
May 14, 2010Aspirant
Having issue getting Automatic service to start "automatic service failed to start".
I've set 1.3 options as follows..
transmission-version = "1.3" (I'm running 1.92)
rpc-host = "localhost" (I've also tried using host name "nas")
rpc-port = 8181 (I use Transmission Remote on this port)
rpc-auth = "admin:xxxxxxx" (Same password that Transmission Remote uses for RPC connection)
Haven't changed any other settings yet. I've rebooted NAS a few times and still can't start service. I'm sure the problem is me but could you steer me in the right direction?
