aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
WhoCares_
May 21, 2010Mentor
You have some tendency to hit any bug on your way, do you ;) For checking whether the service is running, do
This should list all the running automatic tasks. Meanwhile I go and check why the green button is not working.
-Stefan
ps ax | grep automatic
-Stefan
