aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
WhoCares_
May 21, 2010Mentor
Forgot to mention in my last post: For a quick check you can use the "automatic -f -v 3" command mentioned earlier. This will tell you what automatic thinks may be wrong with your config. Once that's sorted out, the checkbox and the green light should start to work as one would expect.
-Stefan
-Stefan
