aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
Trial_Master
May 21, 2010Aspirant
Thanks for explaining the behaviors the logic of it all makes a lot more sense now.
Latest Output I'm seeing running those two commands.
nas:~# ps ax | grep automatic
6917 pts/0 R+ 0:00 grep automatic
nas:~# automatic -f -v 3
automatic: /usr/lib/libcurl.so.3: no version information available (required by automatic)
../src/config_parser.c, 429: Configuration file size: 4111
../src/config_parser.c, 475: skipping comment (line 0)
../src/config_parser.c, 475: skipping comment (line 1)
../src/config_parser.c, 475: skipping comment (line 2)
../src/config_parser.c, 463: skipping newline (line 3)
../src/config_parser.c, 475: skipping comment (line 4)
../src/config_parser.c, 599: [parse_config_file] option: transmission-version
../src/config_parser.c, 600: [parse_config_file] param: 1.3 (3 byte)
../src/config_parser.c, 601: [parse_config_file] -----------------
../src/config_parser.c, 318: transmission-version=1.3 (type: 0)
../src/config_parser.c, 475: skipping comment (line 7)
../src/config_parser.c, 475: skipping comment (line 8)
../src/config_parser.c, 475: skipping comment (line 9)
../src/config_parser.c, 475: skipping comment (line 10)
../src/config_parser.c, 475: skipping comment (line 11)
../src/config_parser.c, 475: skipping comment (line 12)
../src/config_parser.c, 475: skipping comment (line 13)
../src/config_parser.c, 475: skipping comment (line 14)
../src/config_parser.c, 475: skipping comment (line 15)
../src/config_parser.c, 475: skipping comment (line 16)
../src/config_parser.c, 475: skipping comment (line 17)
../src/config_parser.c, 463: skipping newline (line 18)
../src/config_parser.c, 475: skipping comment (line 19)
../src/config_parser.c, 599: [parse_config_file] option: rpc-host
../src/config_parser.c, 600: [parse_config_file] param: localhost (9 byte)
../src/config_parser.c, 318: rpc-host=localhost (type: 0)
../src/config_parser.c, 475: skipping comment (line 22)
../src/config_parser.c, 599: [parse_config_file] option: rpc-port
../src/config_parser.c, 600: [parse_config_file] param: 8181 (4 byte)
../src/config_parser.c, 318: rpc-port=8181 (type: 1)
../src/config_parser.c, 475: skipping comment (line 25)
../src/config_parser.c, 599: [parse_config_file] option: rpc-auth
../src/config_parser.c, 600: [parse_config_file] param: admin:mypassword (12 byte)
../src/config_parser.c, 318: rpc-auth=admin:astina (type: 0)
../src/config_parser.c, 475: skipping comment (line 28)
../src/config_parser.c, 475: skipping comment (line 29)
../src/config_parser.c, 463: skipping newline (line 30)
../src/config_parser.c, 463: skipping newline (line 31)
../src/config_parser.c, 475: skipping comment (line 32)
../src/config_parser.c, 475: skipping comment (line 33)
../src/config_parser.c, 475: skipping comment (line 34)
../src/config_parser.c, 463: skipping newline (line 35)
../src/config_parser.c, 475: skipping comment (line 36)
../src/config_parser.c, 475: skipping comment (line 37)
../src/config_parser.c, 463: skipping newline (line 38)
../src/config_parser.c, 475: skipping comment (line 39)
../src/config_parser.c, 475: skipping comment (line 40)
../src/config_parser.c, 475: skipping comment (line 41)
../src/config_parser.c, 463: skipping newline (line 42)
../src/config_parser.c, 463: skipping newline (line 43)
../src/config_parser.c, 475: skipping comment (line 44)
../src/config_parser.c, 475: skipping comment (line 45)
../src/config_parser.c, 475: skipping comment (line 46)
../src/config_parser.c, 463: skipping newline (line 47)
../src/config_parser.c, 475: skipping comment (line 48)
../src/config_parser.c, 599: [parse_config_file] option: interval
../src/config_parser.c, 600: [parse_config_file] param: 30 (2 byte)
../src/config_parser.c, 318: interval=30 (type: 1)
../src/config_parser.c, 475: skipping comment (line 51)
../src/config_parser.c, 475: skipping comment (line 52)
../src/config_parser.c, 463: skipping newline (line 53)
../src/config_parser.c, 475: skipping comment (line 54)
../src/config_parser.c, 475: skipping comment (line 55)
../src/config_parser.c, 475: skipping comment (line 56)
../src/config_parser.c, 475: skipping comment (line 57)
../src/config_parser.c, 599: [parse_config_file] option: use-transmission
../src/config_parser.c, 600: [parse_config_file] param: yes (3 byte)
../src/config_parser.c, 318: use-transmission=yes (type: 1)
../src/config_parser.c, 475: skipping comment (line 60)
../src/config_parser.c, 475: skipping comment (line 61)
../src/config_parser.c, 599: [parse_config_file] option: start-torrents
../src/config_parser.c, 318: start-torrents=yes (type: 1)
../src/config_parser.c, 475: skipping comment (line 64)
../src/config_parser.c, 599: [parse_config_file] option: torrent-folder
../src/config_parser.c, 600: [parse_config_file] param: /tmp (4 byte)
../src/config_parser.c, 318: torrent-folder=/tmp (type: 0)
../src/config_parser.c, 475: skipping comment (line 67)
../src/config_parser.c, 599: [parse_config_file] option: statefile
../src/config_parser.c, 600: [parse_config_file] param: ~/.config/automatic.state (25 byte)
../src/config_parser.c, 318: statefile=~/.config/automatic.state (type: 0)
../src/config_parser.c, 475: skipping comment (line 70)
../src/config_parser.c, 475: skipping comment (line 71)
../src/config_parser.c, 463: skipping newline (line 72)
../src/config_parser.c, 475: skipping comment (line 73)
../src/config_parser.c, 475: skipping comment (line 74)
../src/config_parser.c, 475: skipping comment (line 75)
../src/config_parser.c, 475: skipping comment (line 76)
../src/config_parser.c, 475: skipping comment (line 77)
../src/config_parser.c, 475: skipping comment (line 78)
../src/config_parser.c, 475: skipping comment (line 79)
../src/config_parser.c, 475: skipping comment (line 80)
../src/config_parser.c, 475: skipping comment (line 81)
../src/config_parser.c, 463: skipping newline (line 82)
../src/config_parser.c, 475: skipping comment (line 83)
../src/config_parser.c, 475: skipping comment (line 84)
../src/config_parser.c, 475: skipping comment (line 85)
../src/config_parser.c, 463: skipping newline (line 86)
../src/config_parser.c, 475: skipping comment (line 87)
../src/config_parser.c, 475: skipping comment (line 88)
../src/config_parser.c, 475: skipping comment (line 89)
../src/config_parser.c, 475: skipping comment (line 90)
../src/config_parser.c, 475: skipping comment (line 91)
../src/config_parser.c, 463: skipping newline (line 92)
../src/config_parser.c, 475: skipping comment (line 93)
../src/config_parser.c, 475: skipping comment (line 94)
../src/config_parser.c, 475: skipping comment (line 95)
../src/config_parser.c, 475: skipping comment (line 96)
../src/automatic.c, 514: verbose level: 3
../src/automatic.c, 515: Transmission version: 1.3
../src/automatic.c, 516: RPC host: localhost
../src/automatic.c, 517: RPC port: 8181
../src/automatic.c, 518: RPC auth: admin:mypassword
../src/automatic.c, 519: foreground mode: yes
../src/automatic.c, 520: config file: /etc/automatic.conf
../src/automatic.c, 521: Transmission home: /root/.config/transmission
../src/automatic.c, 522: check interval: 30 min
../src/automatic.c, 523: Upload limit: -1 KB/s
../src/automatic.c, 524: torrent folder: /tmp
../src/automatic.c, 525: start torrents: yes
../src/automatic.c, 526: state file: /root/.config/automatic.state
../src/automatic.c, 530: 0 feed URLs
../src/automatic.c, 531: Read 0 filters from config file
../src/automatic.c, 535: No feed URL specified in automatic.conf!
[10/05/21 21:32:34] ../src/automatic.c, 128: Shutting down daemon
../src/list.c, 228: [cleanupList] size before: 0
../src/list.c, 239: [cleanupList] size after: 0
nas:~#
