aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
WhoCares_
May 21, 2010Mentor
Trial_Master wrote: Oh okay sorry I hadn't set those values yet as I was still trying to get past the initial error of service not starting.
A real "shoot yourself in the foot" scenario there ;) I just checked whether I can add some basic test to solve that or at least issue a warning but that would require such an amount of work that I for now consider it not an option.
Trial_Master wrote: I just made a 10 euro donation for all your troubles I really appreciate the time you've offered me getting this going.
Much appreciated, that also puts you in the "Top 3 Donators" list.
Trial_Master wrote: Looks like I have a tick and green dot now.
I guess somewhen I'll have to write a FAQ entry about how that stuff really works (as opposed to "How the user thinks it would work"). Basically it's a finite state machine with two locks that would need three locks instead. Or as my professor used to say: it's "ideal scenario logics applied to a weird world" ;)
-Stefan
