aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
WhoCares_
May 22, 2010Mentor
You could try this: regular expression generator. Needs some time of getting used to though.
As for the episode numbers: You should be able to do this with regular expressions as well, however, I don't know how good automatic's parser really is.
-Stefan
-Stefan
