aresgodofwar30
Mar 02, 2010Aspirant
Need help compiling Automatic for Duo
I found Automatic and want to use it with Transmission. I've gotten a lot of packages installed on my Duo to compile, but I'm stuck. Here is the error I'm getting: checking for LIBXML... configure...
Trial_Master
May 23, 2010Aspirant
Hi Stefan, if you lead me in the right direction with the pattern formatting I would appreciate it. I have tried the examples in automatic.conf and nothing is happening so I don't know if it's the patterns I'm using or some other setting? I'll PM you details as requested.
