NickMar
May 14, 2022Aspirant
Need Transmission for ReadyNAS ULTRA 4 (x86)
Hello Need Transmission for ReadyNAS ULTRA. The following page https://kb.netgear.com/24557/RAIDiator-Third-Party-Add-ons unfortunately links to the wrong pages. Thanks a lot
May 14, 2022Guru - Experienced User
The x86 link for transmission https://kb.netgear.com/24557/RAIDiator-Third-Party-Add-ons?article=24557#p2p_share is for 4.2.x systems - though very old, so not current.
One thing that you might consider is converting the Ultra to run OS-6, and then getting transmission from https://rnxtras.com/readynas-os6-x86
- NickMarMay 14, 2022Aspirant
how can i converting the Ultra to run OS-6?
- StephenBMay 14, 2022Guru - Experienced User
The steps are
If you do decide to convert the Ultra, then you should also consider increasing the RAM. Shipping OS-6 NAS have at least 2 GB of RAM, stock Ultras only have 1 GB. Some have found that 1 GB isn't enough. Upgrading to 2 GB is inexpensive, and is simple to do.
The steps are:
(Optionally) make sure the latest BIOS is installed before you do the conversion. To do this you install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS. Do this after you backup the NAS. This isn't necessary, but if you so want to update the bios it is easiest to do it prior to conversion
Basic instructions for the conversion itself are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
Netgear won't provide paid support on a converted NAS, so that is one consideration. There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
- NickMarMay 15, 2022Aspirant
So i suppose that no working links to transmission for raidiator 4.2.xxx . i found the following post https://community.netgear.com/t5/ReadyNAS-Storage-Apps-Current/Transmission/td-p/632419 but don't see the link to *.bin file in this post.
